How do I open gallery of clock faces for Sense?
How do I open gallery for watch face
5 REPLIES 5
Hi @Nonac33,
You have to have the Fitbit app on your phone.  Log in with the same credentials you used to make the account here.  In the upper left corner, you'll see your profile picture.  Tap it.  Then select the "Sense", this will take you to your Device Settings.  From there, select "Gallery" and you should be all set.
Please note that if you want to change the clock face, you will need your Bluetooth ON.
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
It's part of the fit bit app, you load the ones you want and then the watch remembers the 5 most recent ones.
Hi @Nonac33  -  If you are looking for the ECG app, it should be on the watch face as part of the firmware. Swipe watch face left till you find the launch icon and click on it.
Yes, found thank you
Got it, Thank you
