12-26-2020
08:41
04:28
12-26-2020
08:41
04:28
I enabled Fitpay, but now it forces me to use the PIN just to see my watch.
I do not see an option to remove the pin or not use Fitpay.
How do I disable Fitpay entirely?
Hi @DavidKY.
Open the Fitbit app on your phone - tap on your profile picture - tap on Sense - scroll down to "device lock" - you should be able to change the pin setting to Fitbit pay only. I don't believe there is a way to disable the pin completely, but if you're not actively using fitbit pay you shouldn't ever be asked for a pin.
I haven't tried this myself (so it might not work), but maybe going to "my apps" and removing the wallet app might have the desired effects.
I checked your second suggestion, @N8teGee. Unfortunately, the Wallet is not under Apps. It is a category all its own under Account. I was not able to delete it. But your first suggestion should work.
@SunsetRunner Yes it seems to be the case now. I remember wallet being available in the apps section as a removable app previously, I guess the ability to uninstall has now been removed.
