04-26-2024
04:54
13:40
LizzyFitbit
04-26-2024
04:54
13:40
LizzyFitbit
how do i program the time on my fitbit sense? i ask because there is no more fitbit app.
and before you smart off with "you have to use google", i assure you that i bought a $300 fitbit Sense, not a google.
Best AnswerHi @ingenius1 I"m using my Fitbit account until I am required to move to Google in 2025. There is a Fitbit app, but it's only for compatible smartphones or tablets. There is no Windows app now.
Hi @ingenius1 - you only need a phone with the Fitbit App on it.
If you have an old phone and you remove the Fitbit App you may not be able to install it again (Fitbit supported devices)
Also see Why won't my Fitbit device sync? And
How do I change the time on my Fitbit device?
