09-26-2020
10:05
10:06
LizzyFitbit
09-26-2020
10:05
10:06
LizzyFitbit
How do I switch to google assistant on Fitbit sense?
Moderator Edit: Clarified subject and updated label
Best Answer11-20-2020 06:07 - edited 11-20-2020 06:09
@TaliaP The firmware will roll out on a progressive basis. You should hopefully be offered it over the next week or two. Until then all you can do is wait patiently. Bear in mind, currently Google assistant is only available to US users. Other English speaking countries should follow shortly.
I still haven't received the update myself either, so you are not alone.
Best Answer11-26-2020 05:33
11-26-2020 05:33
I was finally able to see it but now it shows this when I try to select Google assistant. I'm in the US.
Best Answer11-27-2020 14:29
11-27-2020 14:29
I'm the same and I'm in the UK! Hopefully won't be long now! 😊
