12-07-2020
02:32
12:51
LizzyFitbit
12-07-2020
02:32
12:51
LizzyFitbit
HI though i have been using a Fitbit device since Aug 2013 I just bought a FITBIT SENSE and need help with the ecg recording ,Cant see it on my fitbit watch
Im a premium member
thanks
Dr Gandhi
Moderator Edit: Clarified subject and updated label
ECG functionality is dependent on your location as usually local health authorities need to provide approval before Fitbit can enable it. Currently I believe ECG is only available in a limited number of countries.
Best Answer1. You may not be in a country that has approved it yet.
2. It was in an update so if you are in the US try doing the updates and it might show up.
3. If it still doesn't go to the app store and see if you can just install it that way.
Best AnswerIs it that you do not have the option to record the EGG on the watch @Gandhi?
Or are you able to record the ecg but do not know where to review the results?
Best Answeri figured it out but i really would like to know what all everyone is using it for . thanks
Best AnswerTheir might not be @Chay1705 at least not until South Korea gives their approval.
Some users say that they where able to change their location and install.
