So I can use the Google Assistant on my Sense if I keep my phones location as the US (thank you for those that figured out that trick) but slight problem, I need my location settings to be correct and what not, not to mention Australia is listed as a country that can indeed use Google Assistant.... Any ideas/tricks/Fitbit fix your **ahem**.
There are 2 issues and 2 components.
1) Google Assistant language and Fitbit settings.
2) Fitbit setup and usage
To setup Google Assistant in the phone app you need US everywhere.
Once the setup is complete you can set Google Assistant language as you want.
However US must remain in Fitbit for it to work consistently. It can work, once set up, with other settings but there are some instances that break the setup, and it has to be redone.
Don't know of this helps.
