11-21-2021
22:00
10:48
LizzyFitbit
11-21-2021
22:00
10:48
LizzyFitbit
I know you're suppose to wear the fitbit a finger width from your wrist bone and that it's suppose to be able to move up and down (but I don't like it too loose that it's moving up and down. I just find it irritating. 🙁 )
I've been wearing elastic bands and even those have been sliding down (not where the Sense clock on top of my arm is) My arm just gets a little bigger at that part where I'm suppose to wear the fitbit (finger width from my wrist bone) So I find that I don't know that I can wear it a finger width from my wrist bone.
Does anyone else just wear it at your wrist or not quite a finger width from your wrist bone?
Moderator Edit: Clarified subject and updated label
Hi, @Abbs , it sounds to me that you are having a problem getting the band size just right. I think the test for the right degree of looseness is are getting an HR reading (if not it's too loose) If you've tried all the buckle settings available on your band you could try a fabric hook/loop band which by its nature is infinitely adjustable. I tend to wear mine a little loose and it slides down to my wrist bone, I still get my HR so I'm happy. I hope this helps.
Cheers
Gr4ndp4 | UK
