03-11-2022 14:40
03-11-2022 14:40
I noticed the ECG report is a separate pdf from the main wellness report ( the one that contains RHR, Sleep etc).
How many of these are there and also why can't Fitbit put all wellness reports into just a single pdf to download. Instead of separate ones from sperate apps??
Thanks in advance.
04:23
04:36
03-12-2022
04:23
04:36
Hi @Kenzibit
As far as I ccan see there is only the two reports that can be downloaded.
I think combining the ECG into the wellness report wouldn't work too well as the wellness report covers the whole year. With the ECG it's likely you would want to download individual readings/reports (the ones of concern) and not the entire year's worth.
I would recommend posting your suggestion over on the feature suggestions board (here), as this is the best way to get the attention of the developers. It also allows other users to vote on the idea so that Fitbit can see how popular it is.
03-12-2022 04:49
03-12-2022 04:49
@Kenzibit There is a big reason why the two can't get combined. The Wellness Report is a Premium feature that isn't Fitbit model dependent. The ECG feature is only available on two models and only in certain countries. It would be a nightmare to try and merge the two features into one report.
Laurie | Maryland
03-13-2022 10:54
03-13-2022 10:54
Just discovered a 3rd one under Blood Glucose.
Best Answer03-13-2022 10:55
03-13-2022 10:55
At least if the feature isn't available, it doesn't show on the report, that's what my Versa did at least.
