09-25-2020 18:28
09-25-2020 18:28
The Sense version of the app and web desktop are missing exercise shortcuts and I see no way to reorder or change the exercises.
09-25-2020 18:46
09-25-2020 18:46
From what I have seen you cannot manually rearrange them.
however once you use an exercise it goes to the top in a new recent tab. In the end your most used should filter their way to the top.
09-25-2020 18:46
09-25-2020 18:46
09-27-2020 22:56
09-27-2020 22:56
Id like to remove the excersizes id never use.
09-28-2020 05:56
09-28-2020 05:56
Another option is to add the exercises (up to 4) to the Double Press Shortcuts - you can specify a particular exercise rather than just the exercise app.
12-01-2021 06:55
12-01-2021 06:55
Can you please give instructions on how this is done?
03-14-2022 02:06
03-19-2022 09:38
03-19-2022 09:38
Thank you! I've been searching for 2 hrs to put walk and jog to the top... just got this Sense to replace the recalled Ionic. So good to know the ones I use the most will automatically jump to the top. Thank you again!
03-19-2022 09:40
03-19-2022 09:40
Ohhhh this might be nice too! Thank you! I was trying to figure out how to change the order so walk & run were at the top.
03-19-2022 09:42
03-19-2022 10:27
03-19-2022 10:27
07-18-2022 06:47
07-18-2022 06:47
Another regression of function. Worked well in ionic why remove this capability?!
