02-17-2021
09:41
16:08
LizzyFitbit
02-17-2021
09:41
16:08
LizzyFitbit
Is it possible to rotate the display on the Sense? Most people wear their watch on their left wrist, I have to wear it on my right. When I tilt my right hand up at the wrist, it presses the button on the side of the watch. Usually long presses it. It would be nice if I could wear the watch "upside down" and still have the display in the current orientation.
02-17-2021 10:12
02-17-2021 10:12
Sorry, but no. You cannot change the orientation.
02-17-2021 10:12
02-17-2021 10:12
04-08-2021 12:31
04-08-2021 12:31
Agreed! I’m a lefty & wearing mine for the first time today. Already it’s annoying me pressing the button with my hand 🤦:female_sign:
06-21-2021 12:28
06-21-2021 12:28
Im a lefty and I wear my fitbit on my right and I'm having the same problem I really want to get the button on the inside so it doesn't keep long pressing etc hope we can get a answer that will give us a option
07-24-2021 16:10
07-24-2021 16:10
I'm ambidextrous right dominant, I actually wear my watch on my left wrist but with the watch face on the inside of my wrist as it's more comfortable. This might be the solution to your problems as well. If you wear on you right side, put the watch face in the inside of your wrist.
11-02-2021 20:14
11-02-2021 20:14
I'd love to see this basic functionality added to the watch. I'm forever hitting the capacitive button 😭.
11-03-2021 00:57
11-03-2021 00:57
Hi, @justinfreitag - there is a version of the SimpleClockPro watch face (analog and digital) in the gallery called SimpleClockPro-L which has its face rotated specially for this problem. Of course it is only the clock face that is rotated. It might help.
02-03-2023 11:01
02-03-2023 11:01
that's why fitbit sucks!
05-04-2023 06:12
05-04-2023 06:12
Just reverse the wrist bands, I did the same
05-04-2023 06:36
05-04-2023 06:36
That rotates the watch itself, not the display. The display would be upside down.
05-04-2023
06:44
17:00
05-04-2023
06:44
17:00
Hi @Nitin_Suvarna - thanks for the suggestion, though to save the bother of playing with bands just put it on the other way round.
As @MikeS1971 says, that would mean the display is upside down and then as a partial measure use the upside down clock face mentioned earlier, it's not ideal but helps stopping the button being accidentally actioned on your right wrist.
