08-29-2020
13:02
14:47
LizzyFitbit
08-29-2020
13:02
14:47
LizzyFitbit
Is the Sense capable to give the altitude ? Or any other Fitbit model ? Cheers
@Viro_Major there are apps in Fitbit app store that can give you approximate altitude upon calibration (you need to know your current altitude to input in the app in order to calibrate).
Hi, @Viro_Major , the Fitbit sense includes an altimeter. However this will not give you your altitude reading; instead it will detect subtle changes in altitude (10 feet) to indicate how many “floors” you have climbed.
There is currently no Fitbit that will report your current altitude.
I hope this helps. Welcome to the forums.
Thank you Julia
I live in the mountains and it would be practical. Hopefully this suggestion can be considered, especially since it is geared up for what it takes
