09-04-2020
18:12
13:31
LizzyFitbit
09-04-2020
18:12
13:31
LizzyFitbit
was wondering if the fitbit sense is compatible woth the straoght tall rebel 4
09-04-2020 18:44
09-04-2020 18:44
Hi @tonyjen1987 it's not so much the name of the phone or the carrier, as it is the phone meets the basic requirements, which you can find here - click to go there.
09-04-2020 18:44
09-04-2020 18:44
09-06-2020 17:42
09-06-2020 17:42
Do you currently have a Fitbit @tonyjen1987. in most cases it is the Fitbit app that is compatible. The tracker model doesnt matter much.
Your post seems to be the only post mentioning the Rebel.
09-06-2020 18:31
09-06-2020 18:31
09-06-2020 18:51
09-06-2020 18:51
Your phone is running Android 8.1 which is fine as Fitbit currently requires Android 7.0 or newer builds.
09-06-2020 22:22
09-06-2020 22:22
@tonyjen1987 if your versa works fine, I would assume Sense will as well. You can always return the purchase within the grace period.
09-11-2020 10:05 - edited 09-12-2020 15:36
The issue usually is not in the tracker, butin the software app on the phone. If the Fitbit app works with your current tracker it should work with the Sense. I've noticed that your Fitbit account is over a year old.
