10-30-2021 15:00
10-30-2021 15:00
So frustrating. Literally plagued by bugs with every feature I try.
Calls on watch - not working
Messaging/WhatsApp notifications - not working
Extended EDA scan with guided breathing - "heart rate data not captured"
Short EDA scan - "phone not connected"
Countdown timer - no sound when has finished.
I'm sure there are more but this is just a quick post from memory. Literally every one of these problems I Google and many, many others have had the same issues. Many of the posts are from one year ago or more and they're STILL not fixed.
I've only had the watch for 2 days and I'm sick of it already, more time spent googling trying to work out how to fix the problems than using the features!
And the "solutions" even if they work are too convoluted to try - like "uninstall/reinstall" this or that. Disconnect/reconnect. Restart phone, then watch or vice versa.
If I can't trust that bluetooth remains connected to allow notifications and calls then I can't use it for that as its not reliable.
All in all totally frustrated. I can't believe anyone has kept these and just not sent them straight back to fitbit, they're not fit for purpose!
10-30-2021 16:38
10-30-2021 16:38
I just purchased the Sense today. It is fully charged and I did get it to partially sync where it will show the stats on a windows 10 laptop. I keep getting a green checkmark and then the red X when trying to update. Cannot get anything on the display except the message to download the app in many different languages, even after it has synced.
I have reset everything multiple times, which does not change anything.
10-30-2021 19:04
10-30-2021 19:04
Maybe try to reinstall firmwear? Idk
10-30-2021 20:30
10-30-2021 20:30
What phone and OS are you running?
Best Answer11-01-2021 02:25
11-01-2021 02:25
Hi, it's a Poco f2 pro with miui 12.5.3. Apparently there is a new fitbit firmware update due but since a lot of these same issues go back at least a year and have not been fixed over many updates I'm not hopeful they'll suddenly fix them in this update. I know that it is said that battery optimisation on some androids could be a problem so I've already turned it off for fitbit - didn't help.
Best Answer11-01-2021 11:44
11-01-2021 11:44
Edit: Spo2 completely flaky aswell. Has worked one out of 3 nights despite correct watch face and installed spo2 app. Worked the middle of the 3 nights (night 2 of 3) despite no changes between nights!
Best Answer11-01-2021 12:07
11-01-2021 12:07
Oh, and Google assistant wouldn't set a timer for 1h50mins on the sense. It does on the phone no problem. Just an annoyance really but seems no reason why it can't do this. On the watch it looks like 99mins is the max timer you can manually set. So that's 1hr39mins I guess is the max.
Best Answer11-04-2021 13:38
11-04-2021 13:38
Seriously? No reply from anyone at fitbit to address these issues?
Best Answer11-05-2021 15:01
11-05-2021 15:01
Updated the firmware yesterday and unfortunately the problems are still there, stops recording my bike rides 15 min into a ride, etc. etc. Basically i have all the sand problems listed above
11-11-2021 13:06
11-11-2021 13:06
Yeah, shame it seems these issues (and this thread) are basically being ignored
Best Answer11-11-2021 13:25
11-11-2021 13:25
users mostly on here..hardly anyone from fitbit here..
Best Answer11-11-2021 15:40 - edited 11-11-2021 15:43
You got a lot of issues…..
I’m not familiar with your phone or I’d try to help.
Contact Fitbit support is my suggestion. Maybe they can help.
