My water logged is showing I've met my goal on the app, but The Sense shows no water logged. Calories, exercise, sleep ect is all correct on both. I've tried rebooting, force stop, Uninstaller & restarted. Frustrated!!
Best AnswerHi, @Dpospangler, welcome to the community, you are entering your water consumption in the app but it is not appearing on your "Sense". To confirm the entry in the phone app you do need to touch "save" in the top right corner (sometimes missed) alternatively this sounds as if you are not successfully syncing. Why won't my Fitbit device sync? provides guidance and advice about the process. If you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
Best AnswerYes, pushing save is a no brainer. That's not the issue. After reading through this forum, apparently I'm not the only one having this issue.
