07-09-2021
07:15
15:05
AndreaFitbit
07-09-2021
07:15
15:05
AndreaFitbit
Can you adjust the touch sensitivity on the screen. It takes 4 or 5 touches to bring the screen up. And how do you get wrist movement to turn screen on
Best Answer07-09-2021 10:32 - edited 07-09-2021 10:33
Don’t know if you can adjust sensitivity but to get the wrist movement turning watch face on, hold button for a couple seconds you’ll see the below face. Tap on the watch image (middle bottom row).
07-09-2021 12:35
07-09-2021 12:35
Thanks for your reply
Screen wake is turned on
Still will not come on with wrist movement
Will keep trying
Thanks Again
Best Answer07-09-2021 15:09
07-09-2021 15:09
Welcome to the Fitbit Community @Kensense and thanks for your help @Clove6060. Thank you for sharing your Sense sensibility adjustment inquiry.
Currently there's no an adjustment to set the Sense sensibility to moves and turning it on with screen wake. Sometimes you have to make a strong movement to turn your watch on.
I hope this information helps.
