10-07-2020 03:05
10-07-2020 03:05
Hi I have an hauwei p30 lite. Problem is I cant get my notifications through. It keeps coming up in red I have to restart which I do and nothing but same message.
I did the test run for calls and its OK just my Gmails and messages.
Can anyone help
Best Answer10-07-2020 05:27
10-07-2020 05:27
Had the same issue, I also own a Huawei just different model.
Noticed that my persistent Fitbit notification was gone and couldn't get it back on, so I've decided to reset my phone to factory settings (I like to do it from time to time anyway)
Installed Fitbit from scratch, connected my Sense and all is good since then, it was 3 days ago 😁 I have my notifications, sync works all the time (before it would stop few times a day) Stress Management works (was crashing app all the time before)
Basically, all my Fitbit issues are gone since the full reset of my phone. I know it's a harsh solution not everyone would be willing to go for but it worked for me so I'm just sharing it.
This is my missing notification that is back on since the phone reset
10-07-2020 09:02
10-07-2020 09:02
Thank you will give it a try
