08-01-2021
03:00
12:28
AndreaFitbit
08-01-2021
03:00
12:28
AndreaFitbit
I have the exact same problem.
Best Answer08-01-2021 03:01
08-01-2021 03:01
Same here! Totally agree. Is there a way to solve the microphone issue, or is there a hardware problem? Guess not, since it started just after the firmware update...
Best Answer08-01-2021 04:33
08-01-2021 04:33
Hi @Eliarn I've moved your posts into a fresh thread, rather than hijack an 9 month old unrelated thread that already had been hijacked 5 times.
Have you tried shutting the sense off, then power in it on.
On sense, settings - Help - About - Shutdown.
05:40
12:32
AndreaFitbit
08-01-2021
05:40
12:32
AndreaFitbit
Thanks - yes, also shutting down Sense doesn’t help.
Moderator edit: updated post.
Best Answer08-04-2021 04:17
08-04-2021 04:17
If anyone is interested - the FitBitt support team couldn't do anything about the malfunctioning microphone, so finally I had to get a new Sense watch, which I hope will work as it should...
Best Answer08-04-2021 17:26
08-04-2021 17:26
You did check the settings to see if the mike is enabled?
Best Answer08-05-2021 12:58
08-05-2021 12:58
Welcome to the Fitbit Community, @Eliarn. Thank you for letting us know that you got a new Sense because support couldn't do anything about the malfunctioning microphone.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Thanks for your assistance @Rich_Laue.
Keep on visiting the forums.
