08-05-2021
11:09
14:37
AndreaFitbit
08-05-2021
11:09
14:37
AndreaFitbit
Hi, I wish to find a running app for
my fitbit sens that we could add alarms for pace or for distance. For exemple, I wish to have it vibrate or ring every km. Do you know witch app to use?
thanks
Best AnswerHello @Dom_charbonneau and welcome to the Help forum. You do not need a separate app to do this. You can set a vibration reminder to alert you every km. When you choose the Run exercise, you will see a tiny "^" at the bottom of the screen. Swipe up until you see Laps. Tap on the Auto Count, Set rule choice. Then tap on Kilometers, then set to 1.0 km. Swipe to the right to back up, then swipe down until you get back to the top of the page. Start your run. Now your Sense will vibrate at every km. A screen that has time, distance and pace data will appear on the screen for about 10 seconds. Then it will go back to your active Run screen. At the end of your run, you can see all your km split times on the screen before you exit the app on your Sense. You will also have them on your phone app exercise details. Your Sense will keep these settings until you change them.
No additional app needed. I don't think that choosing "Laps" to get to this setting is intuitive. But I think this is what you are looking for.
Laurie | Maryland
