06-19-2021
13:59
18:46
LizzyFitbit
06-19-2021
13:59
18:46
LizzyFitbit
Hello Fitbit Conmunity / Support
My Fitbit Sense worked well after I bought it in California, now I'm traveling in Europe and most of features don't work: ECG disappeared from the menu, I don't see sleep time and the Android app seems to be reporting only walking time properly
Any idea how to fix it?
Moderator Edit: Clarified subject and updated label
06-19-2021 16:46
06-19-2021 16:46
that normal behavior traveling messes the watch up for a day or two but as you are traveling out side of united states ecg app and other apps are not yet released in certain country's in europe and around the world so will not have access to them as for the basic stuff gps and pedometer and such will be wonky for a few days then it fixes it self i suggest you put it on the charger and have your phone connected to a wifi while it charging to help the watch calibrate itself when you move around to different country's out there same thing will happen as well as when you come back home.
Best Answer08-03-2021 19:55
08-03-2021 19:55
Thanks for your reply
I'm back home to California for 2 weeks and only managed to repair ECG app, it shows up again on the Fitbit screen
As for all statistics in the mobile app - still nothing returned back
a) deleted and reinstalled app >> no difference
b) purchased Premium >> no difference
I do still full stats in the Desktop view of the Dashboard: https://www.fitbit.com, but not in the Android Mobile app
Any solution to this (ugly) problem?
