02-25-2022
10:42
18:49
EdsonFitbit
02-25-2022
10:42
18:49
EdsonFitbit
My watch was working fine, but now the screen is black. I tried holding the button done, as shown in the you tube example, but I am not even getting a vibration. I have had this watch since December. Any thoughts?
02-25-2022 13:37
02-25-2022 13:37
I am having this same issue.
A week previously I started having difficult moving off the Watch face to see my step count as well.
02-25-2022 13:51 - edited 02-25-2022 13:52
@Shari1961 welcome to the Fitbit community.
Before the screen went black, what was your battery percentage? If it was very low it probably died on you. A lot of people have charger cable issues, so make sure your connection is clean and firmly placed. I would let it sit on the charger for 15 minutes or so and then reattempt to long pressed the button on the side. Since it's dead you won't feel a vibration so make sure you press it like you're squeezing not just pushing.
02-25-2022 14:07
02-25-2022 14:07
I cannot answer for @Shari1961 but for myself my battery was at 70%.
02-25-2022 14:18
02-25-2022 14:18
I’m having the same issue. It will only show the main clock face now, and when I swipe up, it goes black. Also won’t sync with weather any more.
02-25-2022 14:20
02-25-2022 14:20
this is what happened to me
02-25-2022 14:47
02-25-2022 14:47
I had this issue I had to clean out the charging pins with a cotton bud as it wasn’t able to charge. After I did this it charged and came back one
17:29
18:47
EdsonFitbit
02-25-2022
17:29
18:47
EdsonFitbit
It charges just fine. The clock face appears but now when I swipe up, the
screen is black.
It's not dead - I charge successfully every evening. My clock face displays and if I tap the clock face, I can see what different measurements are applicable. However, it no longer scrolls up to see the different screens. I can swipe right and see the different icons. Just can't scroll up.
Moderator edit: format
02-26-2022 06:15
02-26-2022 06:15
It just came off the charger. In case it didn't charge, I put it back on the charger but still nothing.
02-26-2022 11:05
02-26-2022 11:05
My sense is doing the same thing. I was charged greater than 50%. I cleaned the back and the charging cord but still no vibration and a black screen.
02-27-2022 05:35
02-27-2022 05:35
My Sense is also dead. Black screen. Nothing happens when I press buttons. No effect after being over 24 hours in charge. No effect to change charger.
02-27-2022 06:59
02-27-2022 06:59
I have my fitbit sense on charge since last evening, tried cleaning up the charging point both on wire and watch, tried long press several times, the watch is not getting charged at all. Showing black screen since yesterday. I have this watch since January this year. Was there any recent update which is causing these issues in Sense devices?
02-27-2022 10:27
02-27-2022 10:27
I got the same problem, before went black the red light stay on for a while and I couldn’t scroll on the screen.
I tried to press the side button but I got no vibration
02-27-2022 20:29
02-27-2022 20:29
02-27-2022
22:25
18:48
EdsonFitbit
02-27-2022
22:25
18:48
EdsonFitbit
Problem seems to be resolved. After 0% screen it started and begun to charge. In some ways this seems like an erlier programming error on the side of Firbit.
03-02-2022 18:46
03-02-2022 18:46
Hello everybody, thank you for visiting the Fitbit Community.
I'm sorry to hear about the difficulties you experienced with your Fitbit Sense devices. Thank you for trying to get them resolved before contacting us.
If your Watch doesn't vibrate when it is plugged into the charging cable, please follow these troubleshooting steps to resolve battery issues.
Whether your Sense vibrates and sync but the screen is black, please perform a restart and try to change the clock face.
If you followed our recommendations shared above without luck, the best way to get help for this problem is to chat with us online or give us a call. Please click here to get connected.
@Jodie76 I noticed that you've been in touch with Customer Support. I'm pretty sure they will do their best to provide a high level of support. Thank you for your patience while dealing with this situation.
@FIuser I'm glad to hear that your problem was resolved. Thank you for letting us know.
Thanks for your support, @eezeepee @Ceri111uk.
Have a nice day.
Best Answer03-03-2022 03:33
03-03-2022 03:33
Mine does the exact same thing! Ugh!
03-03-2022 08:00
03-03-2022 08:00
3/3/2022
Update! I left the watch sit for a day and when I picked it up again, it said 0%. I cleaned the back where it charges and put it back on the charger.
I am guessing when it hit 0% it reset the watch, because I was able to charge it and it is working now.
03-03-2022 15:06
03-03-2022 15:06
My Fitbit Sense started this nonsense yesterday, was on charger for 24hrs, switched outlets etc, and still nothing. I wiped the back of watch and prongs on charger w wet qtip and wiped it off. It's now working. 🙄 charging etc.
Guess since I wear it constantly, except in or around water, that it gets "gunked" from body oil, skin etc. 🤔
03-03-2022 18:27
03-03-2022 18:27
i had this previos imput... is more explaining about what happend with my watch
Yesterday....I was walking in the street, i wanted to se the time, I checked it (7:03pm) and after that all went wrong.
First I noticed i couldn't change to other screens; then I realized the red light stayed on and the watch started to get hotter and hotter; also the side bottom doesn't vibrate. Nevertheless, I managed to do a rest (by pressing the side bottom for 10 sec) i see the logo but the screen and then i saw the main screen with the time 7:03 (despite the fact is already passed 10 minutes) and then went black.
I did 3 times the rest and I got the same result after that. I tried to do a hard reset by getting into the fitbit app but my cell phone didnt find the watch, so i couldnt do it. I try to connect the watch but nothing shows up. Today. I tried to charge, since the screen is totally black, but I think it is not charging now.
