02-25-2022
10:42
18:49
EdsonFitbit
02-25-2022
10:42
18:49
EdsonFitbit
My watch was working fine, but now the screen is black. I tried holding the button done, as shown in the you tube example, but I am not even getting a vibration. I have had this watch since December. Any thoughts?
03-03-2022 18:44
03-03-2022 18:44
About a week ago my Fitbit Sense went Black.
And still nothing.
My issue sounds almost exactly like all of you'rs.
03-04-2022 07:29
03-04-2022 07:29
03-06-2022 16:57
03-06-2022 16:57
Hello everybody, thank you for visiting the Fitbit Community.
@BlondeAgent If you followed the instructions shared in my response here without luck, you can chat with Customer Support online or give them a call. Please click here to get connected.
@Shari1961 @Pwalsh @PghJanet I'm glad to hear that you've resolved the issue with your Fitbit Sense. Thank you for letting us know.
@woyos According to our records Customer Support is currently providing assistance to your case. They will find a way to resolve your issue as soon as possible.
@Champ7777 If seems that you've been in touch with Customer Support already. If you have any questions about their resolution please let them know in order to get further assistance. You can find the Fitbit Warranty here.
Have a nice day.
03-06-2022 20:23
03-06-2022 20:23
I just had this issue. I pressed the reset button and a message suggested to disconnect Bluetooth then reconnect. This worked.
03-07-2022 03:46
03-07-2022 03:46
03-07-2022 03:59
03-07-2022 03:59
Newest update
I've been charging mine for several days now and the logo screen has come on.
When I Press and hold the button to restart, the vibrations are back.
It kind of goes back into a restart loop
However
If I hold the button down for a while like 1 minute.
It goes from a logo screen to a black screen and it sits like that for a while, before showing the logo screen again and before you're able to feel vibrations again.
When I was first trying to fix it. One of the instructions I came across was to unlink and disconnect you'r fitbit sense from both the Fitbit app and Bluetooth.
Neither worked for me.
But it's good to know what has worked for some of you guy'ses.
03-07-2022 14:24
03-07-2022 14:24
08-11-2022 02:24
08-11-2022 02:24
I just installed the most recent update. I put my sense on its charger as it updated. It was at 96% when I took it off. I scrolled through the new interface, tried the google assistant app, didn't work.
Not too phased, I ate dinner and in that time my screen went blank. I switched blue tooth on and off, closed and reopened the app, tried a hard reset, didn't work. No vibration when pressing the side button, no vibration or screen light up when I put it on the charger again. It appears to have died right after the update.
Twice it vibrated when I touched the side button, but screen was still blank. It's again giving me zero response now. The app is unable to connect to it. The charge level on the app is 95%, which means it was almost fully charged the last time it connected to the app.
It's really strange that this happened right after the newest update.
Is my Sense now dead? Because none of the troubleshooting options are working.
Please help.
08-11-2022 13:06
08-11-2022 13:06
Hello everybody, thanks for your comments.
Welcome to the Fitbit Community, @Milaska.
Whether your Fitbit Sense doesn't turn on, please follow these troubleshooting steps to resolve battery issues.
If you followed our recommendations without luck, I would recommend chatting with us online or give us a call. Please click here to get connected.
Have a nice day.
06-05-2023 07:50
06-05-2023 07:50
I have had many versions of this topic. Black screen, still vibrating, not able to reset. I believe it is salt water that is causing me trouble as this happens after being in my boat. A fresh water cleaning and wipe off fix the problem for me.
