Hi @dani43 - if you are using many features like Snore detection and SpO2 it can drain the batter y quite quickly.
Try and recharge it, If it won't, then it may need cleaning or the charge cable may be faulty - see all the instruction links in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
As it's under warranty, if you don't succeed try chatting with Fitbit Support directly.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
They should be able to send you a replacement cable.
Probably best to contact Fitbit Support directly. They may be able to help you.
If the watch is found faulty it may be better to take it to the shop for a new replacement, rather than accepting a refurbished replacement from Fitbit and dealing with sometimes drawn out return and shipping issues that may occur.
