11-24-2020 10:18
11-24-2020 10:18
I'm not even getting Gmail notifications on my Sense. Plus the automatic time zone setting keeps turning itself off and won't update time changes. Bugs, bugs and more bugs. Plus still no Google Assistant update. Ugh Thinking about keeping my Active Watch 2 instead.
Best Answer11-24-2020 11:49
11-24-2020 11:49
Hi @SunsetRunner Google assistant is coming with the current firmware that is being rolled out.
I'll assume that you are getting other notifications.
First thing to check is that you get Gmail notifications on the phone while the phone is locked.
Then I would set the main email program for your Gmail app. If this doesn't work, disable this, and try setting gmail up through the app notifications. This way we might do some troubleshooting.
11-24-2020 12:18
11-24-2020 12:18
Best Answer11-24-2020 18:10
11-24-2020 18:10
Just got the new Google Assistant update. Maybe that'll fix Gmail notifications never coming through. Wonder if it'll fix changing time zones automatically? Guess I'll see tomorrow. Speaker for calls is embarrassingly low though. And no contacts app so can't even make calls from watch. Kind of wishing maybe I hadn't of returned my Active Watch 2. It was just a better watch for me. Oh well. There'll be something else better and newer come out soon. The Sense sure ain't no flagship watch though. I don't think.
Best Answer11-24-2020 18:38
11-24-2020 18:38
The problem is on the phone. Have you checked the details for your unknown phone model. I assume it is android. Has it been tested as being compatible.
Have you searched these forums for your phone model?
11-25-2020 03:47
11-25-2020 03:47
Best Answer11-25-2020 04:42 - edited 11-25-2020 04:43
The tracker doesn't care what app sent the notification it receives. It simply displays every notification the phone sends.
There is a reason that the phone is not sending Gmail notifications. The tracker is not the issue.
Does gmail notifications pop up on the screen, even when the phone is locked?
Is Gmail selected under the default mail?
Let's disable it there and tap App Notifications and choose Gmail from here
11-25-2020 06:39
11-25-2020 06:39
Best Answer11-25-2020 07:49
11-25-2020 07:49
Just another thought - I have outlook as main email and that came through. For a test I added gmail notifications but they did not come through. This morning I got the update and after that I re-tested and the gmail notification came through together with the earlier test notification! Possibly the restart of the tracker helped.
Best Answer11-25-2020 09:01
11-25-2020 09:01
Best Answer11-26-2020 04:56
11-26-2020 04:56
After uninstalling and reinstalling the Fitbit app on my phone Gmail notifications started coming through. Hopefully it'll last. However, time zones still won't change right, in getting no temp readings after 5 days or no stress score. So not sure what's happening. Running latest Google Assistant update on Pixel 4 XL.
08-13-2021 03:53
08-13-2021 03:53
I have tried uninstalling the fitbit app and I am still not getting Gmail notifications, I never had any problems with the Charge 3 I had previously but have had many with Sense !.
Best Answer08-13-2021 17:14
08-13-2021 17:14
What phone are you asking for help with @Galaxy66? Should I assume that notifications for Text and any other apps like Facebook and Twitter come through?
Have you tried disabling the G-mail notification, and re-enable? This should force the app to request the proper permissions, of which the user will need to agree to.
Best Answer08-13-2021 23:16
08-13-2021 23:16
I am using a Huawei P30 Pro and i get no notifications at all and when swiping down it states "Notification centre you're all caught up"
08-14-2021 04:59
08-14-2021 04:59
Have you reviewed the setup instructions? You are all voucher up because the tracker has not received anything to display.
Best Answer08-22-2021 11:41
08-22-2021 11:41
Well, I have now ditched the Sense for now and enabled a fitbit Ionic and still not getting notifications through, I can only assume that my Huawei P30 pro is not fully compatible the fitbit app as doing a search on phone compatibility throws up many issues with that phone.
