06-15-2022 06:18 - edited 06-15-2022 06:21
This is my 3rd watch within less than 2 months and its not working 3rd one lasted half a day there is something seriously wrong
With the replacements taking 5/7 i reckon i have been able to wear it less than amonth not great for s £299 watch
Best Answer06-15-2022 06:57
06-15-2022 06:57
I had the same problem and with the cost of a sense it should work longer than it does. I am going out this weekend and buy an Apple watch is what I should have done to start with. MY ADVICE DO NOT BUY A SENSE FITBIT!!!
06-15-2022 07:21
06-15-2022 07:21
Did you get your money back fitbit are saying due to fact it more that 45 days since i brought it can have a refund which. Is a joke as i havent had one thats worked for more than a couple of weeks
Best Answer06-15-2022 07:21 - edited 06-15-2022 07:22
I have asked for them to put in a complaint
08:07
09:56
06-15-2022
08:07
09:56
Hi all, is it possible there is a battery charging problem and the watch just runs out of battery and doesn't charge.
Have a look at the issues in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen if the symptoms match yours, the watch may be fine, but need cleaning or simply the charge cable replacing which is quite a common problem..
