12-28-2020 17:04
12-28-2020 17:04
I am not getting any notifications while exercising. How do I fix this? Thanks in advance
Best Answer12-29-2020 00:22
12-29-2020 00:22
You could check this is set up on your watch. Scroll left until you can see the settings app. Open the app and then scroll up until you see quiet mode. Click on quiet mode and you will then see Focus mode. Ensure this is off. If not, click on the toggle until it displays off.
hope this helps
12-28-2020 22:06
12-28-2020 22:06
@CaitlinHowell is your watch in dnd or sleep mode (swipe right on the main screen to access quick settings). Have you tried rebooting your watch (press and hold the button for around 10 sec until screen goes black and Fitbit logo appears)?
12-29-2020 00:22
hope this helps
12-29-2020 12:22
12-29-2020 12:22
I wasn’t sure if you meant exercise notifications or like outside texts...if you meant exercise notifications...like moving through heart rate zone, Take a look at page 55 in the manual. I just found out that you can tap an exercise and you can scroll up on the screen instead of just starting your exercise. One of the options is to get notified when you move into a zone. This has been my pet peeve and hopefully this will fix it for me. Else, I think, the other two checks from the other posters should help you.
Best Answer12-29-2020 18:16
12-29-2020 18:16
I found the focus mode and turned it off and it fixed it. Thank you!! Didn’t realize focus mode was on there.
