12-10-2021 10:56
12-10-2021 10:56
I set up the device lock to `Enabled (Recommended)`. It explicitly says "Enter PIN if you take off the device or every 24 hours"
When I take it off, it turns off (and I see the green lights on the back are off). If I then tap the screen, everything is still accessible without a PIN.
Why isn't this working??
Best Answer12-13-2021 17:59
12-13-2021 17:59
Thank you for visiting the Fitbit Community, @Fry-kun.
I'm sorry to hear about the difficulties you experienced with your Fitbit Sense. Thank you for the information provided.
I noticed that you've been in touch with Customer Support. I'm pretty sure they've done their best to provide a high level of support. Thank you for your patience while dealing with this situation.
Have a nice day.
08:28
11:36
EdsonFitbit
12-14-2021
08:28
11:36
EdsonFitbit
Yeah, they said they would record this as a bug for devs.
Though I'm a bit suspicious that it might be my hardware.. is the same behavior with other people's Sense, too?
Moderator edit: word choice
Best Answer12-14-2021 09:53
12-14-2021 09:53
If the led's turn off, the watch knows that it is off of the arm. Everything else with the device lock is software related.
01-25-2022
04:10
13:03
EdsonFitbit
01-25-2022
04:10
13:03
EdsonFitbit
Same thing with my Fitbit sense. Got it as a Christmas gift. I noticed in January, this month, that my watch never asked for PIN#. I do not keep watch on all the time. Numerous calls with FitBit customer service, Factory reset done, re-sets done, a lot of syncs and nothing work. I asked for a replacement Fitbit sense which I got, and the new Fitbit sense does not ask for pin when I put my watch on. So much for security safety.
Moderator edit: all-caps
Best Answer01-25-2022 08:25
01-25-2022 08:25
Mine eventually started asking for it, I think after I opened & closed every app on the watch. I didn't want to reset the device just to retest it, but try that.
If it doesn't work, maybe some extra app I installed did the trick.
Please reply here whether that helped or not
Best Answer01-25-2022 08:34
01-25-2022 08:34
I can demonstrate the pin request consistently works for me if I take off my watch, let it sit for 2 seconds, put it back on, wake up the screen, and swipe down for notifications.
09:14
12:59
EdsonFitbit
01-25-2022
09:14
12:59
EdsonFitbit
When I take my fitbit sense watch off my wrist, the green light behind the tracker is still on. Is that supposed to be that way? Thanks
Not working for me, but thank you
Moderator edit: format
Best Answer01-25-2022 09:16
01-25-2022 09:16
@eezeepee that's great but not helpful to us, as getting the that normal store is not obvious.
Best Answer01-25-2022 09:22 - edited 01-25-2022 10:00
@Psalm1from what i can tell, it depends what you do with the watch after taking it off. If it's placed on a light colored surface, it keeps trying to detect the arm. If the green LED faces up or placed on a dark surface, it'll turn off quickly.
Either way, the PIN is requested, even if the LED didn't turn off completely
Best Answer01-25-2022 09:29
01-25-2022 09:29
Thank you. I placed the watch on a darker surface and the LED light stopped blinking. Unfortunately it fails to ask for pin # every time I put my watch on. Thanks for your help.
Best Answer01-25-2022 09:30
01-25-2022 09:30
Yes the lights are still on for me as well. It turns off eventually after a little time.
Best Answer01-25-2022 09:37
01-25-2022 09:40
01-25-2022 09:40
Yes, correct
Best Answer01-25-2022 09:42 - edited 01-25-2022 09:42
Try installing these apps:
"QR Codes" by Brian Ouelette
"Image viewer" by Maurizio Fazio
Then open each of them on the watch.
See if that does anything for the PIN
01-25-2022 09:43
01-25-2022 09:43
@eezeepeenote, my PIN works a expected after some magic
01-25-2022 09:58
01-25-2022 09:58
Thank you, unfortunately those apps did not help me. I installed those apps, synched, and no request for pin when I put my watch back on. Maybe the problem is with the latest software updates
Best Answer01-25-2022 10:00
01-25-2022 10:00
Ok sorry to hear that didn't work ☹️
Best Answer01-25-2022 10:03
01-25-2022 10:03
It’s okay, thank you for your help
01-25-2022 10:43
01-25-2022 10:43
@Fry-kun It's because I replied. lol. Well that's good it's working now. Hopefully it'll be consistent.
