07-14-2021
09:15
15:54
DavideFitbit
07-14-2021
09:15
15:54
DavideFitbit
I am receiving all notifications except incoming call notifications.
I have Calls enabled under notifications on the Fitbit app.
On-wrist calls is all set as well
When I go to my phones Bluetooth settings and choose Sense controls, the following 2 are the connections options. Calls and Input device. Calls is not enabled, and when I try to enable it, it reverts back to disabled right away.
I have factory reset the watch. I have uninstalled the Fitbit app. I have rebooted my phone. None seem to work.
When I do the test call from the Fitbit app, it does show up, but when I do an actual call from another phone, nothing shows up.
I am using a Samsung S20FE and a Fitbit Sense.
15:53
09:39
07-14-2021
15:53
09:39
Hello, welcome to the Fitbit Community forums, @Ryan0512 @Jennie36.
@Ryan0512 Thank you for all the information about what you've been experiencing with your Sense watch.
Before considering other options, please check all the compatibility requirements here and if you already tried all the steps listed in this article to resolve problems with notifications.
In addition, please make sure that you have the latest version of the Fitbit app installed and that you've disabled the Do Not Disturb mode on the watch's settings.
Hope this helps.
Best AnswerI went through all of the setting on my phone and everything thing is set as required on the app and the phone. The bluetooth setting still won't let me toggle to enable calls, which I think may be the root of the issue. Phone is supported and on Android 11. Fitbit app is up to date. Seem like my last resort is to factory wipe my phone which I really don't want to do.
16:35
09:39
07-16-2021
16:35
09:39
@Ryan0512 Thank you for your reply and confirming that you already tried all the troubleshooting steps suggested.
If you continue to experience the same inconvenience after all the steps mentioned earlier, the best way to get help for this problem is to chat with us online or give us a call so the Customer Support team can provide you with further instructions. Click here to get connected.
Have a great day.
16:26
09:38
