03-05-2022 07:38
03-05-2022 07:38
My Sense shows that it is paired with my Android, but when I try to use the assistant, it says I need to link
03-05-2022 08:35
03-05-2022 08:35
Welcome to the Fitbit community.
Sounds like you need to complete the set-up for Google Assistant.
Open the Fitbit app, tap your profile in the top left corner to get to Account tap Sense, then you'll see this.
Tap Assistant.
Tap Google Assistant, if that's the one you want to use. Follow the steps to link your Google Account to Fitbit.
03-05-2022 08:45
03-05-2022 08:45
03-05-2022 22:48
03-05-2022 22:48
So I tried what you showed me, and it says "unable to activate". My watch is by my phone when I try to activated it won't. I'm very frustrated. 🙄😔
03-06-2022 00:13
03-06-2022 00:13
Hi @MissusV - check this help and especially countries at the bottom. Voice Assistant on Fitbit Smartwatches
