09-15-2022
07:06
11:40
09-15-2022
07:06
11:40
I updated my phone now my Fitbit won’t take a charge. I tried different outlets with no luck.. help!
Best AnswerI'm confused, are you saying that your Fitbit device won't take a charge? If that's the case, then this isn't the right forum to post that question.
one cruise ship at a time!
Best AnswerYou can find your device's Android version number, security update level, and Google Play system level in your Settings app. You'll get notifications when updates are available for you. You can also check for updates.
See which Android version you have
Open your phone's Settings app.
Near the bottom, tap About phone and then Android version.
Find your "Android version," "Android security update," and "Build number."
Get the latest Android updates available for you
When you get a notification, open it and tap the update action.
If you cleared your notification or your device has been offline:
Near the bottom, tap System and then System update.
You'll see your update status. Follow any steps on the screen.
Get security updates & Google Play system updates
Most system updates and security patches happen automatically. To check if an update is available:
Open your device’s Settings app.
Tap Security.
Check for an update:
To check if a security update is available, tap Google Security checkup.
To check if a Google Play system update is available, tap Google Play system update.
Greeting,
Rachel Gomez
