02-28-2022 14:49
02-28-2022 14:49
I have had ongoing discussions first with telephone CS who then escalated to a supposed higher level tech support. There have been about 15 emails back and forth with no resolve to my issue.
The problem is that some days the Snore and Noise detect feature provides a snore report and others (the majority of the time) it does not. Out of the 38 days that I have had my Sense, it has worked on 12 days.
Tech support has had me do a factory reset, check to make sure app is updated (it is) and then most recently, uninstall and reinstall the app. Then they told me I could not put it in sleep mode because this turns off the microphone, it does not as I was able to use the assistant feature and it worked.
I honestly think that tech support has no idea at all what is wrong and that they trying to run out the clock so my 45 days expire allowing me to return the device. I have asked them on numerous occasions to replace it with brand new device and not a slightly used device. They have said that is not their policy, total BS as the device is still in customer satisfaction window to return.
Has anyone else had issue with Snore & Noise detection?
Best Answer02-28-2022 15:59
02-28-2022 15:59
I know snore detection makes a big battery hit. Could it be battery level is not high enough to allow recording on some nights? I suggest checking battery level before each night to see if that corresponds, or make sure to charge it in the evenings.
Most people find the battery usage makes it not practical to use every night but instead use for a few nights just to get a baseline; then check it again in a month or so, or if suspect something has changed.
02-28-2022 18:26
02-28-2022 18:26
Best Answer03-22-2022 04:20 - edited 03-22-2022 04:23
I turned mine on for the first time last night. Do not see a report today. I plan to leave it on for a few nights (keeping battery level up) and see if I get one. I lost 20% battery charge with 5 hours sleep. Normally I loose 20% every 24 hours. Something drained the battery.
03-22-2022 05:55
03-22-2022 05:55
03-22-2022 06:10
03-22-2022 06:10
@Clove6060 Losing that much over night sounds about right. You'll probably get a delayed report tomorrow. You should get one for the next night sleep though.
03-22-2022 06:12 - edited 03-22-2022 06:15
Thank you for the replies. I am leaving SD on and charging the sense frequently over the next few days/nights. Looking for a baseline at this point.
I’ll report back with success/failure.
07-19-2023 12:57
07-19-2023 12:57
Every time I select it in the app it goes to the screen crashes and then goes back to the main menu
