06-11-2022 09:26
06-11-2022 09:26
I have noted on the on-line FitBit forum that this seems to be a problem for a significant number of Sense owners. I have only had mine for a number of days and it started failing almost immediately. Contacted Customer service, got a case number, sent photos. Customer care rep did not say a word about this being common. It's to the point now that I bent down to pick up something with the arm it was on and that movement caused it to fall off. It falls off frequently at night while sleeping, which negates any utility of the sleep tracking functions. I have bought numbers of FitBit devices through the years and did not expect the company would sell a device with this type of commonly repeated failure.
06-11-2022 10:23
06-11-2022 10:23
Hi, @Reno6796, I'm not convinced this is a "common" issue, I do see reports from time to time but nowhere near as many as other issues such as the charging cable. I have noticed that you must ensure the little clip button is fully engaged when inserting the band, if you have been using a skin product and grit or sand is stuck in the mechanism this can impede the operation. Some of the complaints I've seen actually involved third-party bands, I'm not defending Fitbit.
You may find that cleaning the Fitbit band "end" and the socket on your "Sense" with rubbing alcohol will help.
Cheers
Gr4ndp4 | UK
Best Answer09-23-2022 18:13
09-23-2022 18:13
Bought my Sense watch, and the band won't stay snapped it. It's not the band. The clasp on one side has no spring tension like on the other. Fitbit won't stand behind the warranty because I bought it on eBay.
09-23-2022 19:19
09-23-2022 19:19
my suggestion is to try a new band or if it is the clasp, then buy a case/band protector.
09-23-2022 22:30
09-23-2022 22:30
