The last month my sence has calculated resting heart rate wrong. It has to be wrong, as it is placed among the highest readings I have each night. I have seen on the forum that this has been a problem a long time, and that thread was closed for discussion. Why is it then not fixed? Most of the use my Sence has is in monitoring my fitness, and this makes it impossible. Also I find it frustrating that it affects my scores on everything else. It just makes the experience of using the watch bad. I have so far otherwise had much use of this watch.
Hi @SunsetRunner - try syncing the watch and then do a full Shutdown from the watch Settings menu. Wait at least 10 seconds before placing on the charger to restart it and charge it, or push the button.
Best AnswerThank you for the reply, I appreciate it. I have tried this, but the problem is the same. Max pulse last night was 71, lowest 57. It still calculated my resting heart rate to be 71. Since the watch seems to have to sync to give resting heart rate, I have always believed the app to be the one who does the calculations.
I might add that it used to calculate a testing heart rate somewhat under max heart rate at night before. Somewhere in between max and min. As it is now, it sets my resting heart rate over what I often have during resting in the daytime. Had it been like this from the start, I would not react. But is seems to me to have changed.
