01-03-2021 04:35 - edited 01-03-2021 08:19
I received a fitbit sense for Christmas but I can't get my ring doorbell notifications on the fiibit. I have changed every setting I can find I've tied deleting both apps and reinstalling is there anyway this can work. Please help as I like the most of the other features and my £35 galaxy fit worked perfectly I can't see why this shouldn't.
Best Answer11-10-2021 02:13
11-10-2021 02:13
Unfortunately there doesn't seem to be a fix (after all this time). There are various "work arounds" but I've had limited success with them.
The latest one I've tried is setting up a routine in the Alexa app to send a notification when motion or the bell is pressed. Unfortunately these notifications seem to be of a lower priority (at least on Android), so are often received minutes after the even has happened. So in other words completely useless. I haven't got an iOS device, but perhaps it may work better there.
Best Answer11-10-2021 04:01 - edited 11-10-2021 04:04
Works well with iOS. I have it setup and it worked flawlessly. However, I ended up toggling the notification off. I get a lot of packages from UPS and Fedex and the battery drain was not worth it. I decided to just use the phone app for Ring Notifications.
If it’s a priority, consider buying an iOS phone. There does not seem to be an Android fix.
09:02
05:56
11-10-2021
09:02
05:56
Has anyone tried the Macrodroid solution for Android phones?
From the Playstore link
Someone may have mentioned that a firmware update or a Google update possibly resolved the Ring notification.
Best Answer12-30-2021 01:16
12-30-2021 01:16
Steps on how you were able to get your notifications. Thank you
