03-13-2021 05:27
03-13-2021 05:27
For some reason my SPO2 score is not being uploaded into my Fitbit app over the last 3 days. The Sense shows the score, but it doesn't make it to the app.
Anyone else experiencing this issue?
Best Answer03-13-2021 05:53 - edited 03-13-2021 05:56
Hi, @MattJ71, welcome, You may find this of use How do I track blood oxygen saturation (SpO2) with my Fitbit device? A reliable fallback is to clear the cache in the Fitbit app (after syncing) and restart your phone. If it's still stuck restart your Sense (after syncing)
Cheers
Gr4ndp4 | UK
Cheers
Gr4ndp4 | UK
03-13-2021 11:32
03-13-2021 11:32
Thanks! That worked. All the lost data showed up.
Best Answer03-14-2021 05:39
03-14-2021 05:39
I’m having the same problem. Where do yo go to clear the cache in the Fitbit app? Thanks!
Best Answer03-14-2021 10:00
03-14-2021 10:00
Hi, @dcr1980 , welcome to the community. Go to the Fitbit app in your phone app tray (I'm sorry I can't be more precise as I do not know what phone/operating system you are using) in Android this will be via settings>apps. Swipe up to and open the Fitbit app and open storage. at the bottom of the screen touch "Clear Cache".
Cheers
Gr4ndp4 | UK
Best Answer03-16-2021 07:55
03-16-2021 07:55
Could you tell me how to clear the cache on an Iphone please?
Best Answer03-16-2021 10:29
03-16-2021 10:29
Hi, @gainas, welcome, I'm sorry I do not have any experience with "Apple" phones or their O/S. The setting you are looking for is in the "Fitbit" app on your phone on the storage element of the app. Once you have cleared the cache it's a good idea to restart your phone.
Cheers
Gr4ndp4 | UK
Best Answer03-21-2021 05:57
03-21-2021 05:57
Same problem since Wednesday. The clock on the device shows the SpO2 does not sync to the app on my IPhone.
Best Answer03-21-2021 06:10
03-21-2021 06:10
Do not know how to clear cache in IPhone. I restarted both the phone and the device and it did not solve the problem.
Best Answer03-21-2021 08:32
03-21-2021 08:32
There is no "storage element" that I can see.
Best Answer03-21-2021 09:18
03-21-2021 09:18
Hi, @Georgefellner , The only other thing I can suggest is to sync your phone, remove the Fitbit app, restart your phone, and re-install the app. It will take up to three nights to repopulate the data, each will require you to have at least three hours of uninterrupted sleep.
I'm sorry I do not have experience with Apple O/S.
Cheers
Gr4ndp4 | UK
Best Answer03-21-2021 09:26
03-21-2021 09:26
Best Answer03-31-2021 13:11
03-31-2021 13:11
Mine works sometimes and then it will not record SPO2 on the watch nor the app. Ironically if I post this problem in a forum...all of a sudden that night SPO2 will be recorded on the watch and app. Go figure! It is so frustrating!
04-01-2021 06:46
04-01-2021 06:46
Hi, @Gail1034, have you reviewed this article How do I track blood oxygen saturation (SpO2) with my Fitbit device? You will note you must have 3 hours of undisturbed sleep for the algorithm to work. If your device consistently fails to generate a value I suggest you ask a friend or family member to wear it at night (keeping it registered on your own Fitbit account). The data stream that generates the measurement is your HR, How do I track heart rate with my Fitbit device? will provide advice & guidance. A restless night definitely can prevent a reading.
I hope this helps.
Cheers
Gr4ndp4 | UK
04-01-2021 07:02
04-01-2021 07:02
Do you know if I change the SP02 watch face will I have to wait for three days for the SP02 to register again? Help appreciated.
04-01-2021 07:11 - edited 04-01-2021 07:12
Hi, @gainas, I'm not sure, you can only try. With other devices, once the tile in your Fitbit app is established it seems to stay and display relevant available data.
Sorry, I can't be more precise.
Cheers
Gr4ndp4 | UK
04-01-2021 10:25
04-01-2021 10:25
Best Answer04-01-2021 10:26
04-01-2021 10:26
Best Answer04-01-2021 11:15
04-01-2021 11:15
Hi, @Gail1034, may I clear something up, "you guys" is not me, How to: Identify a Fitbit Moderator or Employee - Fitbit Community . If you click the blue medallion under my charming photograph it will link you to an explanation. You can of course talk to "Customer Support" here I recommend you use the chat facility or phone.
Cheers
Gr4ndp4 | UK
Best Answer04-01-2021 15:07
04-01-2021 15:07
Did not mean to insult you. You answer questions as if you worked for fitbit. My bad!
