12-05-2022
18:51
09:25
12-05-2022
18:51
09:25
Quick View quit working even though I have it set as "on" in settings. It used to work but then quit. I restarted my Sense, and it still doesn't work. I hate having to press the button every time I want to see the time, etc.
Best Answer12-05-2022 19:06
12-05-2022 19:06
Hi @SunsetRunner - Quick view can be active but is temporarily disabled if your watch is in sleep mode.
Swipe the watch face to the right to get to Quick Settings and check that both sleep and do not disturb are not enabled, once they are not you should see wrist wake (Quick view) is enabled, but if not enabled it.
12-05-2022 19:06
12-05-2022 19:06
12-06-2022 09:30 - edited 11-27-2023 06:11
Hi there, @SunsetRunner. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Sense before reaching out. I understand how you must be feeling.
I agree with @Guy_, please check if by any chance DND or sleep mode has been enabled. When the do not disturb setting is on:
Sleep mode turns off automatically when you set a sleep schedule. To set a schedule:
Hope that helps.
Best Answer12-06-2022 15:20
12-06-2022 15:20
Thank you! Sleep mode was on!
