I hate to say it but the seal probably failed. It has been said to degrade over time. If you’re within the warranty period (1yr or 2 yr depending on location) you’re in luck. Contact support. If outside warranty you’ll most likely be offered a discount on a new watch.
Do a search and you’ll find threads of others who’ve had the same failure and their outcome.
