Sense 2 uses a differently sized band from sense
Why does my new Sense 2 not fit my Sense watchbands? I have several bands for the Sense and thought that the bands were supposed to be the same, but I'm pretty disappointed that they don't match, because that means that I can only get the really high priced bands direct from Fitbit.
2 REPLIES 2
Hi @WillSch  that is the problem with third party bands. The Fitbit brand is made to fit, but the off brand ones don't always work as well. You might need to check a few out before finding one that works well for you.
Stepping in the U.S.A. since September 2013. Android 14
Unfortunately the bands even from Fitbit sense don’t fit the Sense 2. There is some intrinsic difference in the way the attachments are made. Hence my post.
Sent from my iPhone
