09-29-2025
12:07
10:21
DavidFitbit
09-29-2025
12:07
10:21
DavidFitbit
My Fitbit sense isn't charging. When I put it on charge, after a few minutes it starts to beep and with error message stating that it's below operating temperature and requesting me to warm it up. What shall I do?
I tried to wear it outdoor to see if it'll warm up but no solution.
Hi @Kayode, welcome to the Fitbit Community! It's great to have you here!
Let me help you with the issue you are currently experiencing with your Sense that is not charging because it's "too cold".
According to the user manual of the Fitbit Sense, the device require some environmental conditions:
Environmental conditions
If you live where the environmental temperature falls below 14 ºF (-10 ºC) you may get a similar message. If you are certainly sure this is a mistake, try to re-establish the device's temperature parameters by restarting it. To do so, press and hold the button for 10 seconds until the Fitbit logo appears on the screen, and then release the button.
Best AnswerHi David,
Just to update you. I wore my device yesterday throughout work period and the little power was drained out completely. I got back home and put it on charge and for the first time it completed 100% charge which I haven’t achieved in the last 4 weeks. Thanks for your help. I guessed the battery was reset in the period of inactivity. I wouldn’t recommend wearing the device all day in order to drain the battery though (as I did 😂) but I guess maybe simply powering off and let the device warm up for some considerable time might help for some fellows.
