05-02-2021
20:48
17:31
LizzyFitbit
05-02-2021
20:48
17:31
LizzyFitbit
In my Sense, the Do Not Disturb and Sleep Mode are both “on” and are both locked with messages that the other function needs to be turned off before I can change the setting. Now I don’t get any notifications, nor do I have an active screen upon moving my wrist. HELP!
Best Answer05-06-2021 05:56
05-06-2021 05:56
Thanks!! FitBit actually pushed another update and the issue resolved itself after charging and going through the new update. I had tried the soft reboot and that hadn’t worked.
05-02-2021 22:44
05-02-2021 22:44
try holding the side button for like 10-15 seconds don't let go until the watch reboots or shows the fitbit logo I noticed a lot of folks give up on trying a soft reboot because they see the Fitbit Pay message pop up just keep holding it down until it does a soft reboot this should get you out of sleep mode & do not disturb. If that fails to fix the issue i would suggest a factory reset UHHH it sucks because you will then have to drop it from the app and reinstall the whole firmware all over again ya know like when your first got the watch and had to do the 4 digit code thing. Try the soft boot first just hold the button on the side until watch restarts up. I hope this helps you out.
05-06-2021 05:56
05-06-2021 05:56
05-07-2021
17:35
06:09
05-07-2021
17:35
06:09
Hi @mmiller333 and @Converse. It's great to see you around the Forums.
@mmiller333 Thanks for every step tried prior to posting! I'm glad your Sense started working well after the firmware update and I'm sure other members experiencing similar issues will find your post very helpful. I hope you continue enjoying the Fitbit experience.
@Converse Thanks for sharing great suggestions to help our member.
07-25-2021 15:35
07-25-2021 15:35
So I also have the sleep mode and do not disturb simultaneously on. The instructions say this is impossible. It's a new Sense. I tried everything in previous posts and completely resynced the device with no luck. Because these are both set to on I cannot turn either off and I cannot adjust settings. I need assistance. Thank you
07-26-2021
11:47
06:08
07-26-2021
11:47
06:08
Welcome, @melscrat. It's nice to see a new face around the forums.
Thanks for sharing these details with me. I'm sorry you're having this experience and to look into this, may I know if you see the Sleep Mode icon in purple and the DND icon in teal color at the same time? Are the other quick settings icons such as Screen Wake unresponsive to tap? Have you tried turning off those settings from the Settings app > Quiet Modes?
If you've not done so, please restart your watch to refresh its performance, open the Fitbit app, pull down on the screen to force a manual sync and monitor its behavior in the next days.
Best Answer02-08-2022 10:26
02-08-2022 10:26
Hi,
my dnd and sleep mode are both stuck to on and saying I can’t turn one off without the other, both saying the same thing. I’ve restarted the watched, re paired, deleted the app re installed it, no new updates. Not sure how I can turn Dnd off
02-08-2022 21:14 - edited 03-03-2022 20:56
02-11-2022
14:20
06:03
02-11-2022
14:20
06:03
Hi there, @Guy_. @Ld2022 Welcome on board.
@Ld2022 Thanks for joining this thread and letting us know about your Sense. Also, for taking the time to troubleshoot your watch prior to posting. I understand where you're coming from and because the suggestions shared here didn't work for you, I'd recommend contacting our Support team. That way, they can investigate what may be occurring and provide you with further assistance. They're available via chat and phone, just click here to get connected with them.
09-12-2022 20:38
09-12-2022 20:38
Using this method to turn off the setting worked. Thank you!
09-13-2022
12:52
06:03
09-13-2022
12:52
06:03
Welcome on board, @Shaymarie.
Thanks for your efforts, I'm glad the steps shared in this thread worked for you. Let me invite you to visit the Health & Wellness board where you can find inspiring stories, make new friends and start your own topics. Have a good one! 😊
Best Answer09-13-2022 22:56
09-13-2022 22:56
Hi, I was troubleshooting this on a sense and kept trying to use the settings scrolling to the right. Did all the same stuff as you, and spent a lot of time trying to figure it out. Made sure updates were installed etc. I had given up for the night and ran across this thread:
https://community.fitbit.com/t5/Sense/Turn-off-quot-Sleep-mode-quot-on-Fitbit-Sense/td-p/4684866
Essentially there are really nondescript bubbles scrolling to the left... one with a moon and one a minus. The moon was lit up on this sense and I selected it to disable... apparently that was sleep mode. Needless to say I felt silly and it's a very poor setup on fitbit's part. At any rate, I don't know if this is your issue, too, but maybe it will help to share.
09-13-2022 23:12
09-13-2022 23:12
09-13-2022 23:19
09-13-2022 23:19
Best Answer09-17-2022 02:00
09-17-2022 02:00
Ways to fix-
Way 1: Disable Do Not Disturb
Way 2: Restart Your Device
Way 3: Adjust Do Not Disturb
Way 4: Close Do Not Disturb While Driving
Way 5: Reset All Settings
Way 6: Restore Your Device via iTunes
Way 7: Update Your iPhone
Way 8: Use Joyoshare UltFix
This may help you,
Rachel Gomez
Best Answer12-29-2022 22:35
12-29-2022 22:35
Thanks to you I also solved the problem.
Best Answer02-05-2023 20:27
02-05-2023 20:27
Omg - thank you so much for posting this! I was so intent on trying to (unsuccessfully) change the settings that it never occurred to me to try swiping to the shortcuts. Yep - there it was, I had somehow bumped Sleep Mode on 🤦:male_sign:. Problem solved.
