01-07-2025
17:45
05:39
DavidFitbit
01-07-2025
17:45
05:39
DavidFitbit
In the app the temperature is set to Fahrenheit. Yet the watch displays a Celsius number.
Best Answer01-09-2025 05:37 - edited 01-09-2025 05:37
Hi @stanhilliard, Thanks for stopping by, I hope you're doing well.
Correct me if i'm wrong, it seems you are referring to the default weather application of your mobile device.
To change the units used for the temperature in the Weather app:
Happy 2025!
Best Answer01-09-2025 15:35
01-09-2025 15:35
That fixed it.
It was Celsius and I changed it to Fahrenheit.
But I am confused.
There is another place to set the app settings. From the today page, I selected my picture in the upper right corner. Then [Fitbit Settings], [App settings] [Date, time & units] [temperature]. To specify the units of temperature here doesn't work.
I can't find anything that explains the difference between the method that works and the method that doesn't work?
