Sense battery drained
ANSWERED
after downloading the new firmware I noticed that the battery usage is more than what I expected. I charged it during the download and started using it after I got full charged. After 8 hours of used, the battery remaining 80%. I don’t think it can last 6 full days anymore. How am I going to overcome this? I put to sleep mode at least 12 hours every night and I don’t use it for call and the light level is dim. No gps and just for looking at the time
1 BEST ANSWER
Accepted Solutions
Hi @Shax88. Welcome back.
Thanks for following the suggestions from my post and keeping me posted with the outcome. I'm sorry that your Sense is still not holding charge correctly. I've contacted our Support team so they can create a case and further investigate your watch's behavior. Due to recent events affecting our operations there might be a delay in their reply, but they'll get in touch with you via email shortly.
See you around.
74 REPLIES 74
Hi @Shax88. It's good to see you around.
Thanks for sharing that your Sense firmware was updated and I'm sorry that the battery quickly drained afterwards. As you may know, the Sense should last 6+ days, however it's expected to see the battery draining a little bit after an update because of the time it takes to be completed along with the WiFi usage. The battery life will also depend on how frequent certain features are used, such as the SpO2 Signature or an animated clock face, or if the Always-On Display is turned on.
That being said, I'd recommend to fully charge your watch one more time making sure to use the charging cable that came in the box and follow the tips described in this help article to maximize the battery life. If the issue persists, please let me know so I can help you with this matter.
Keep me posted.
I followed what you said. The next charge supposed to be on Saturday evening for 6 days usage but I saw the battery is 20% left. Still got around 36 to go. As I said, I am not an extreme user. No gps, no checking on spo 2, put to sleep during evening, no taking calls.a decent user and yet the battery drained off faster than the update last week. I just discovered my sense couldn't sync to my phone. I starting to feel insecure after using your product after a month. Please help. It really feel faulty.
See you around.
Hello,
This problem is still occurring since the update on my sense as well. Before that it worked fine. I can now use it for 2 days before I have charge it again. That is at least 1 day shorter then before the update. I’ll hope that you can fix this ASAP.
Kind regards Marcel
Hi @MarcelVermeerx. Welcome to the Community Forums.
Thanks for joining this thread and sharing that your Sense is having the sane issues. I'm sorry this started after updating the firmware and because your watch isn't lasting long enough I've requested a case on your behalf so you can receive further assistance. Please note that due to recent events affecting our operations there might be a delay, but our Support team  will contact you via email soon.
See you around.
I'm having the same issue. Have it set to dim, no gps, hardly use it. Not even 20 hours after I charged it it's 73%
I had a mail from customer support and replied them but until now I still waiting for their mail.
Hi @mummer18 and @Shax88, it's good to see you here in the forums.
@mummer18, thanks for letting me know about your and for checking the settings that impact the battery life. I'm sorry for this inconvenience and I've contacted our Support team so they can look into your watch's behavior and provide you with assistance.
@Shax88, thanks for keeping me posted. While checking your details with our team I was told that your case is under review and they'll get in touch with you soon to help you with your Sense.
Please take in mind that due to recent events affecting our operations there might be a delay. However, be sure that they're working on every case to provide assistance to all our members.
If you need anything else from me, let me know.
They didn’t give me any solution and asked me to close the case. What can I do? Please follow my case. Thank you
Same here. After updating to 5.1 and 5.1.1, battery has drastically reduced and drains about twice as fast, even after factory resetting the watch.
Hi @Shax88 and @EricTune. It's nice to see you participating in the forums.
@Shax88, thanks for keeping me posted and I'm sorry for the experience that you've had. While I don't have access to your case, my best recommendation is to reply back to their email so they can provide you with more details about your Sense's behavior and their resolution. Be sure that our team will work and help you with this matter.
@EricTune, thanks for the steps tried on your own. Because your post didn't mention, please double check the factors that impact the battery life described here and monitor its behavior.Also, make sure to charge it with the charging cable that came in the box.
Tried all the steps / tips already. Also did a factory reset. It's definitely because of the new firmware 5.1/5.1.1
Hi @EricTune. It's good to see you again.
Thanks for trying the suggestions shared in my post. Because your Sense battery is still draining, I've requested a case on your behalf so our Support team can further investigate the behavior of your watch and provide you with further assistance. Note that due to recent events affecting our operations there might be a delay in their reply, but they'll contact you via email soon.
I've also noticed that my Sense has only been lasting 2-3 days since the update for 5.1. I finally decided to see if anyone else had the issue and it seems like there are, and that the update released 2 days ago didn't fix anything.
Prior to 5.1, the sense was definitely getting close to the advertised 6 days, so it seems like the 5.1 firmware update has something to do with the lesser battery life. Seems to me fitbit either needs to figure out and fix this new firmware killing battery life or they need to revisit their labelling of 6 days of battery life.
I've been using the SpO2 watch face since the day I got it. may test out using the boring default stock one for a few days to see if that makes any difference.
Hi @wizll. It's good to see you here in the forums.
Thanks for your efforts. As you may know, the battery life will depend on how frequent certain features are used. This doesn't mean that you shouldn't use them, but as with any other electronic device the features will impact its battery. If you're using an animated clock face, GPS connection, tracking your SpO2 data or the Always-On Display, you may have to charge your Sense more often. That being said, I'd recommend to fully charge your watch and double check the tips to maximize the battery life described here. Please make sure to use the charging cable that came in the box.
Keep me posted.
Having exactly same problem as others describing here. After recent upgrade battery is draining much faster. It used to last 6 days. I'm not heavy user of gps at all. Mainly checking just time from the watch.
How to get this fixed?
Hi @Oopee. It's good to see you in this thread.
Thanks for the information. As you may know, there are factors that impact the battery life of the Sense. While you're not a heavy user of GPS, let me share that if the built-in GPS is used continuously your Sense will have a battery life up to 12 hours. Additionally, some other features such as the Always-On Display, animated clock face or tracking SpO2 data will require you to charge your Sense more often. That being said, may I know if you've followed the tips from this help article? Are your charging your watch with the charging cable that came in the box? After the update did you change any setting on your watch? Please provide me with these details so I can investigate on my end.
I look forward to your response.
This is happening to me too. Since the last update my battery is draining much quicker and I bought it for the 6day battery life. I am not using the GPS, I haven't changed anything different on my fitbit only the update. Are Fitbit going to fix this problem?
I still have the same problem, with or without the suggestion from Fitbit.
I find it very strange that Fitbit is not able to reproduce it or they are
not fully open to us.--
Marcel Vermeer
