11-25-2020
00:59
12:56
LizzyFitbit
11-25-2020
00:59
12:56
LizzyFitbit
after downloading the new firmware I noticed that the battery usage is more than what I expected. I charged it during the download and started using it after I got full charged. After 8 hours of used, the battery remaining 80%. I don’t think it can last 6 full days anymore. How am I going to overcome this? I put to sleep mode at least 12 hours every night and I don’t use it for call and the light level is dim. No gps and just for looking at the time
Mine stopped syncing a few days ago too. I force stopped the app and reconnected it. Now my battery keeps draining. I charged it overnight and already down to 29% this morning.
Best AnswerI was offered a replacement however if the problem is consistent it certainly won't help much. Is this all because of an update???
Best AnswerIf your having a battery issue where it only lasts a few days they will replace just the Pebble..the watch part only..no charger/straps etc. I believe also it needs to be within fitbits warranty period.
Best AnswerI am also having problems with my Fitbit Sense.
I have had my Fitbit for just over a year.
I don't use any special functions, just activity tracking (steps/distance).
I am having to charge my device after less than 3 days, rather than 6+.
I have only recently regularly had the Bluetooth connection on permanently for syncing, and the issue seems worse since the last software update.
A couple of times the device has blacked out with more than 20% of charge remaining.
I am slightly disappointed, as I spent a large amount of money on this device and expected it to last at best capacity for longer than just a year.
Any assistance you can give would be appreciated.
Hi @LMugz - it is unlikely to be a watch problem. Quick battery draining can cause it to switch off and the cause is from updates or features. Look at the main issues and choose which you need and try eliminating ones to see which ones make improvements.
How to resolve the Major issues causing short battery life
Best AnswerI bought this sense on Friday put on charge did ask the installing and updating and yesterday noticed battery down to 55% which is not right cans on here discovered GPS was on so turned off have also dimmed screen which is crap never had to do before and then recharged to 100% ...im actually on my bed only walked 284 steps today as my fit hurting and the battery has dropped to 63% that is not right it has to be effective I only bought this as my battery on my versa 3 only lasting 4 days will this the way its going well last only 2at 7am this morning it was 76% I don't get how it's draining in this manner only thing I have are my watts app messages running but I have that on my vers and I have the brighter screen as my eyes are minus 6 ...im thinking of taking back to the shop I really am
Same watch faces as my versa 3
I've gone through and taken more stuff off and I'm now down to 55% pretty bad as only charged last night but seems to have slowed the draining process.. had fitbits since 2015 so really strange as not had a battery drain so fast before
Best AnswerWill if I tell them it's not meeting the advertised battery time as is false advertising ... like you have had a similar problem think with the charge 4 but fitbit changed the pebble for me after lots of tooing and throwing with getting me to test etc but this is to expensive to be messed around .. ive done a few more deletions of things and will now see how it goes ..if no joy I will take it back to the retailer and if no joy I'll be on fitbit case for a new pebble .. but hoping it's sorted now
Best AnswerI've screenshot your reply and if my problems continue I will have a go with your advise...Thanks so much for replying..I didn't realise so many were having probs with the sense ... I should have researched before buying doh
Best AnswerOh no that's bad hope you've let them know... ive turned virtually everything off recharged it for 3rd time last night in 3 days and I'm hoping it's worked as only dropped to 92% and I'm relatively happy with that but GPS has gone and I've got simpler clock faces no sp02 and just have watts app n telegram messages coming truth not even sure if I've connected calls but I can suffer this xx
Best AnswerJust been on to support team, absolutely useless, didnt help and I wanted to save my chat and even that didnt work, my sennse last about 36 hours and I dont use anything, I dont want the wallet and that, comes up ever ten minutes, set up wallet
