04-17-2021 22:39 - last edited on 04-18-2021 18:07 by LiliyaFitbit
Bought a sense just over a month ago...was working great (aside from low hr reading imo)
In the last week my battery is basically dieing in a day...charged it full the last couple days and by the end of the day its drained. I turned it to dim and deleted some apps but it's still draining quickly
Hi, @Kriz1010 , welcome to the community, if you are using the GPS a lot this will have an impact on battery drain but not to the extent you mention. You may have a hardware fault, in this case, I suggest you contact "Customer Support" here. Use the "Chat" facility or the phone for a prompt reply.
Good Luck
Cheers
Gr4ndp4 | UK
Hi, @Kriz1010, I'm pleased to have been of help.
Cheers
Gr4ndp4 | UK
