01-02-2023
13:28
16:25
LizzyFitbit
01-02-2023
13:28
16:25
LizzyFitbit
Why does my battery not hold a charge?
21:05
10:18
01-02-2023
21:05
10:18
Hi @delphimo - in some cases it is too many features that reduces the time between charges, in others it can be watch fault or error on the watch.
To start afresh restart the watch, charge it fully and see if it helps. If it gets hot while charging, stop immediately, the watch is damaged.
If it charges normally you can check things like Snore detection and SpO2 which combined can use upto 4 of the 6 days battery life. For others see How to resolve the Major issues causing short battery life
01-06-2023 10:57
01-06-2023 10:57
Thank you for your assistance. The Fitbit Sense is only 8 months old and Fitbit will not help nor offer suggestions. I need the heart rate monitor as I have gone into AFib twice last year (2022).
01-06-2023 20:06
01-07-2023 07:18
01-07-2023 07:18
Thank you--I just purchased the Fitbit Sense 2--I hope this lasts longer
Best Answer01-12-2023 02:20
01-12-2023 02:20
请问充电发热损坏是电池还是屏幕,我的游泳进水了,之前还能显示。现在充电有类似细微的报警声,然后发热。请问我该如何处理能恢复。附近没有可以维修的地方
