05-29-2023
11:35
04:46
05-29-2023
11:35
04:46
I’ve tried rebooting and and left it to charge (in 2 different sockets just in case) for over 24 hours, but nothing. It’s also stopped syncing with my phone. Help!
Hi @CatherineJC - it seems it has not charged or switched off. If holding the button 2 seconds doesn't wake it see How to check charge cable - Sense 2/Versa 4 won't charge, won't start or blank screen
Hi there, @CatherineJC. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Sense before reaching out. @Guy_ Thank you so much for your help.
As a first approach, please make sure you've restarted your Sense as described here.
If the restart doesn't work and your Sense doesn't vibrate during the restart process, please follow the steps below:
I've moved your post to the Sense board for organization purposes.
Hi Marre
Thanks very much for getting back to me. I've now tries restarting again, but nothing happens and the screen remains blank. I've also cleaned the connectors, checked alignment, and used different charging points, but no luck. My watch is stubbornly refusing to start, and the screen is still black.
Many thanks
Catherine
Best AnswerHello Marre
I’m still waiting for a response, as my Fitbit is still not working.
I’ve tried everything suggested. Can you help?
Many thanks
Catherine
I have new unit I received this week. Worked for one day and I did charge it to 100%. Last night the screen went black and will not turn on.
Best AnswerI am having the same problem, blank screen and no response, no lights, no reset. It was at 38% when is quit. I troubleshoot it on chat. He was going to elevate it and I was to wait for an email. No email yet.
Hi @TennisWRC - did you try the solutions posted in this topic and it is still not working? if your watch is under warranty it can be replaced.
Sometimes support takes a while to respond and they may come back with a 35% discount if it is no longer under warranty.
In which case you may find another Sense cheaper in the shops and even so it is better to stick with the same model as later models have less features and not everything you have now is available.
Best AnswerHello again
My Sense is still in warranty, but I have not yet had a response to my latest message. In brief, I have tried all the troubleshooting suggestions in this thread, but my Sense will still not charge.
Please advise next steps. Should I send it back?
Many thanks
Catherine
@CatherineJC - if you followed the steps in this topic and nothing works, you can always chat via the Fitbit App, click profile photo, Help & support, Contact Customer support.
If the watch is actually faulty it can be replaced where you bought it under warranty.
