01-16-2021
10:04
10:48
WilsonFitbit
01-16-2021
10:04
10:48
WilsonFitbit
Has anyone had this happen. The button on the side of my Sense has been pushed down and now won't work at all.
01-20-2021
10:42
13:04
01-20-2021
10:42
13:04
Hello @Jenniferohanlon Welcome to the Community Forums! @Guy_ @USAF-Larry Thanks for your input!
@Jenniferohanlon I’ve created a support case on your behalf. You should receive an email from Customer support. Note that they may take a bit long to get back to you due to recent events affecting our operations.
Have a great day!
Are you sure, as its not a button but an indent.
Try this process
Worn on the left arm -
Rest your other thumb on the arm to the left of the watch and forefinger on the back of the hand and do a gentle squeeze of the watch |
No, @Jenniferohanlon, I have not experienced that. I find it difficult to depress the button, but it does work normally. By "pushed down", do you mean it is stuck in the pushed in position and will not return outward?
Yes that's what I mean.
01-20-2021
10:42
13:04
01-20-2021
10:42
13:04
Have a great day!
Best AnswerI am having that same issue. It is draining my battery every day. I can't go to different screens and if and when I do I can't back home. Very frustrating but can't seem to get it unstuck. Please help! I haven't had this watch long.
Will this will work for you? https://community.fitbit.com/t5/Sense/What-I-learned-about-the-Sense-home-button/m-p/4875175#M24898
06-25-2021
10:46
13:04
06-25-2021
10:46
13:04
Hello @Bballgirl. Welcome to the community forums. @stanhilliard It's nice to see you around and thanks for your input.
@Bballgirl I'm sorry for the inconveniences and thank you for the detailed information and for taking the time to repot them. At this time, I was able to see that you have reached out to our Support Team and they have provided information and assistance. If you still have questions or inquiries about the outcome of your case, I recommend replying back to them and they will be glad to continue assisting you.
See you around.
06-30-2021
11:06
08:43
03-25-2022
06:56
13:03
03-25-2022
22:18
13:03
Hello. I've had my Fitbit Sense since September 2020. It suddenly stopped working 2 days ago. No amount of charging or pressing the button for ten seconds to restart, etc. have caused any response. Is the expected lifespan only about a year and a half or is there something else I can try?
04-06-2022
13:08
08:42
04-06-2022
13:08
08:42
Hi @iamshepette - in all probability it's not charging. This could be because it needs cleaning or the charge cable is faulty.
See How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
@iamshepette - the cleaning link is provided in the instructions, you only need click on it.
Best AnswerHi. Thank you for replying. I have three Fitbit brand chargers, two of which were bought within the last year and are used in different places. Even with the low probability that all would quit working at the same time, I did check and all are okay. I've also cleaned the device itself and everything checks out except it won't charge. It's about a year and a half old (purchased Sept 2020) but I expected a longer lifetime. This is my 4th Fitbit and I really hate going another direction after all this time but Garmin and Apple are things I'm going to have to consider. It's a shame because I've really been an advocate for years and I didn't want to change.
12:27
08:42
04-08-2022
12:27
08:42
@iamshepette - what you could do is acquire a USB meter to see what is happening with the charging, such as shown below
If you used a cable attached to a computer it should charge unless they are faulty, which is often the case, even new ones, partly due to the strong magnets attracting objects. Also the 4 holes on the back of the watch can still be dirty and may require a wooden tooth pick or tooth brush to clean them.
If the watch does not vibrate when you push the button, or come on when you charge it it may be faulty. One presumes you are familiar with the use of the button and are not using your nail to operate it because that won't work, it has to be a squeeze between thumb and first finger.
After supposedly charging have you tried syncing, it could be the screen is not working, if you get nothing at all on the screen. Eventually when its completely discharged it should show 0% at some point.
