12-18-2022
15:39
10:28
12-18-2022
15:39
10:28
I am a bit sick of buying new charging cords for my sense! I have gone through three in 12 months!! There is obviously a design fault. One or more of the contact pins gets pushed in so it dose not make contact. I am very careful with it when I attach it???
12-18-2022 16:59
12-18-2022 16:59
I hope you are not buying official Fitbit charging cords from the Fitbit store. Buy a few third-party ones from Amazon much cheaper. That said, I have never had a problem with mine.
Best Answer12-18-2022 17:34
12-18-2022 17:34
Thanks. Fitbit is replacing it free of charge!!
12-18-2022 20:48
12-18-2022 20:48
Good. Even so, I would want to look at prices to consider have spare on hand to avoid going without for the time it takes for Fitbit to replace.
Best Answer12-18-2022 22:33
12-18-2022 22:33
Hi @LindsayJ - to make your new cable last see Tips when using the Sense or Versa 3 charging cable
After 28 months still have the original cable working. Might just be lucky.
