12-31-2020
15:57
06:30
WilsonFitbit
12-31-2020
15:57
06:30
WilsonFitbit
Sense control keeps disconnecting from bluetooth. Any idea why? Using ios. Thanks!
Best Answer12-31-2020 16:34
12-31-2020 16:34
Please note that Fitbit controls only connects to Bluetooth whilst in use I.e making/receiving a call. Please see below from Fitbit help pages:
Note that Sense Controls or Versa 3 Controls might be listed as “Not Connected” in the list of Bluetooth devices on your phone. When you receive a phone call, the controls automatically reconnect. This feature requires more frequent charging.
12-31-2020 16:34
12-31-2020 16:34
12-31-2020 17:17
12-31-2020 17:17
Thanks!!
Best Answer01-02-2021 18:17
01-02-2021 18:17
Thanks, i was wondering about this.
Best Answer01-15-2021 02:39
01-15-2021 02:39
Thanks - great spot! Fitbit would do well to point these things out up front. Would be really helpful Fitbit folks ....?
01-15-2021 06:25
01-15-2021 06:25
Hi everyone. @Dazzar33 @Meribelman Welcome to the Community Forums!
Your suggestions and feedback are very important. So please take into consideration that your comments won't be taken for granted. It seems that the response from @Basandy has been marked as "Best answer" which means that now other users with a similar inquiry will be able to find a faster response.
@Basandy thanks for stopping your insights and suggestions. Your posts are very helpful.
Have a nice day!
01-23-2021 10:04
01-23-2021 10:04
My sense controls keep disconnecting and it doesn’t pick back up on Bluetooth when I receive a text or phone call. Texts are enabled on my phone and my sense controls Will say paired on my device and not connected on my Bluetooth. I try to forget the device and repair, and it works for a minute and then goes back to being disconnected again and doesn’t allow me to receive calls or texts. So any idea on this?
01-25-2021 03:38
01-25-2021 03:38
Hello @Campmeg83 Welcome to the Community Forums! Thank you for the troubleshooting steps that you've followed prior to posting!
Can you confirm if you have a compatible mobile device? The Fitbit app was optimized to work on certain mobile devices to ensure the connection with a Fitbit device, and the performance of its features. For a list of compatible devices, please check:
Which phones and tablets can I use with my Fitbit watch or tracker?
In the meantime, if you have any other devices connected to your phone's Bluetooth, I recommend removing them and setup the Sense controls one more time and keep an eye on the behavior. Other devices connected to your phone may cause interference as well. For more information, check:
How do I take on-wrist phone calls with my Fitbit smartwatch? and How do I get notifications from my phone on my Fitbit device?
I look forward to your reply.
Best Answer01-25-2021 05:10
01-25-2021 05:10
01-27-2021 03:58
01-27-2021 03:58
@Meribelman Thank you very much for the information!
I was reviewing the list of compatible devices and it seems that your mobile device hasn't been added yet. Take into consideration that while some features may work, some others will encounter some compatibility issues. But I recommend checking back later to see if your phone has been added to the list to be fully compatible with the Fitbit App.
See you around.
Best Answer01-27-2021 07:53
01-27-2021 07:53
Best Answer01-28-2021 03:13
03-20-2021 19:16
03-20-2021 19:16
I purchased a Sense, and this is happening to me too, it’s very frustrating. I couldn’t find my phone, and used ‘Find My Phone’ and didn’t work bc it ‘Sense Controls’ was ‘not connected’... I have a Apple 8 plus, and I’ve removed Sense Control and added it back on several times... why can’t it just stay on?
04-06-2021 12:01
04-06-2021 12:01
I just got the Sense maybe a month ago and am having the same issues! I have the new iPhone SE and would always get notifications on my Versa (the original) but switching to Sense I never get notifications anymore
04-06-2021 12:40
04-06-2021 12:40
04-21-2021 01:05
04-21-2021 01:05
I have exactly the same. It’s so frustrating
04-21-2021 05:02
04-21-2021 05:02
I keep having the same thing happen on my S21. It will be connected and working fine. Next thing I know it stops connecting. I have tried disconnecting and reconnecting, buy the "Sense Cintrols" keeps disappearing from the list of devices found in the Bluetooth device list. Super frustrating to deal with this weekly!
06-10-2021 04:54
06-10-2021 04:54
Same here! Except my old watch was an Ionic, which never, ever had these issues. Wonder why they had to overcomplicate the issue and not keep with what worked?
06-18-2021 08:03
06-18-2021 08:03
Same issue here. Sense Controls refusing to connect. I'm using a Samsung S10e. It worked before. Tried connecting via bluetooth settings on the phone and it says I have to try connecting via Sense Controls but I can't figure out where to do that. I've tried restarting both devices, unpairing and repairing... what else can I do?
06-18-2021 08:23
06-18-2021 08:23
I never used to have this problem until my latest 2 Fitbit devices. I'm super frustrated about this now, especially since my phone has zero problems connecting to my daughter's Ace 2, but my super expensive Sense will not stay connected. Ugh.
