06-29-2021
11:48
19:21
LizzyFitbit
06-29-2021
11:48
19:21
LizzyFitbit
My 1 mile loop was tracked correctly by GPS (exercise - walking) on the map, but it looks like Fitbit is calculating the distance ‘as the crow flies’ (straight line across) instead of as a square loop (actual distance walked). So my 1 mile loop is showing up as 0.32 miles. How can I fix this? It used to work correctly.
Best Answer07-10-2021 16:54
07-10-2021 16:54
Hi @AnnaMaeJ does the gps show a map of your walk, or a straight line?
Best Answer07-10-2021 20:06
07-10-2021 20:06
Hi Rich, The map looks accurate (a 1 mile square loop). In the past, mileage was reported correctly (1 mile). Now, the map loop looks the same (square), but the distance reported says 0.32 mi.
