06-28-2021
11:09
11:28
SilviaFitbit
06-28-2021
11:09
11:28
SilviaFitbit
So my 2/3 mo old Sense has been working great until last night. I got sleep patterns - no stages. It’s up to date on software, I haven’t changed anything with the way it’s worn on my wrist or how I sleep at night - last night was a little short at 6.30 hrs but nothing majorly different. Getting this dreaded feeling because I had the same issues with my old Charge 3. When I check suggestions it’s the same rift it’s always been. Also no Stress Management score but all other vitals fine. Anyone have suggestions? I know it was only one night but am still concerned. Thanks in advance!
11:38
06:25
07-03-2021
11:38
06:25
@LindaZz Hi there. Thank you for the detailed information shared.
I see where you're coming from. I appreciate the research done prior to posting. Since it was only one night, please check the following:
In regards to the stress score, try the following:
- Delete the stress tile
- Re-install it
- Wait a night for the stress score to display
Hope this helps.
Best AnswerWasn't there a server issue as well last week, since a lot of people has the same type of troubles with the sleep score? Sometimes, it isn't just the setting of the watch on the wrist that causes an issue...
Best AnswerDid you have your metrics (breathing rate, heart rate variable, Spo2 skin temp, resting heart rate) for that particular day?
